Strange noise from the front end
Old Jul 10, 2021 | 10:07 PM
ironcot's Avatar
Default Strange noise from the front end
Hi I have a Tuscon 2008 and it has developed a noise which sounds like the starter motor but I have fitted a new one, the sound is hard to describe but sounds like putting a piece of card into a bicycle wheel the problem is it intermittent any suggestions would be greatful
Old Jul 11, 2021 | 07:27 PM
When do you get the noise?
Where does it sound like it is coming from?
Is there any way you might post a recording of the noise.?
Is there something you can do to make it happen all the time?
Sound loudest on driver's side , passenger side ?
Not knowing any more info, could the battery be weak contributing to the problem?
As you can see, it's tough to speculate without actually hearing the sound that has your concern.
Old Jul 17, 2021 | 10:55 PM
ironcot's Avatar
Just had a sparky put a meter on the car and came up with P0011 and P0016 and the noise is about middle just need to know is it an expensive job to fix as i am a pensioner as the 2 faults say its connected to the camshaft
Old Jul 18, 2021 | 02:22 PM
There is an oil control solenoid that controls the amount of oil to the camshaft variable timing system.
A good part of the time the solenoid gets plugged up from debris or may quit working altogether. Replacement of the solenoid assy usually takes care of the problem.
devilsedge
Jan 22, 2013 06:05 AM
cecil4speed
May 11, 2012 01:43 PM
CoolElantra
Oct 2, 2010 04:29 PM
hoffy5
Jul 19, 2010 06:44 AM
misstibs
Jan 3, 2005 11:40 PM
