Power steering prob
Old Mar 12, 2006 | 03:25 AM
jmach1's Avatar
Default Power steering prob
Hey, have a 1999 Hyundai Sonata, 75000 miles. The problem is, I at first thought my serpentine belt was squeeling, even though it is only about 5 thousand miles old, sprayed some of that belt dressing on and that did not seem to help the squeel. I then sprayed some wd40 on the bearing to the PS pulley and that stopped the squeel for about 3 minutes. Is this problem most likely the pump bearing going bad? If it is I am assuming that I will need to replace the pump. Any ideas on this?
Thanks JMah1
Old Mar 13, 2006 | 01:00 PM
Chris B Williams's Avatar
Default RE: Power steering prob
Sounds like the pump bearing could be on the way out, but check that the belt has not been tightened too much. This could have caused the problem in the first place. Hope this helps, Chris.
pleil
Dec 14, 2010 03:24 PM
copydoc351
Sep 21, 2010 12:25 PM
bryce
Apr 19, 2009 04:56 PM
beaditya
Oct 27, 2007 10:22 PM
sunset_unicorn
Jan 2, 2006 04:39 PM
