upgrade
Old Jan 13, 2007 | 03:34 PM
eyeruk1's Avatar
Default upgrade
Hi, I plan to install a 2.0 elantra engine in my Scoupe, can anyone tell if any mods to be done to the mounts( using the scoupe's tranny). How to expect the performance?
Old Jan 13, 2007 | 07:58 PM
dodgethis2000's Avatar
Default RE: upgrade
I'm not sure of the mounts, but I'd make sure that the tranny from the scoupe measures properly into the elantra. You should be able to measure the distance between the engine mounts to make sure that they'll align without any modifications. However, I imagine that the mounts will be different. Newer vehicles can have 3-4 engine mounts! While you take the elantra engine out, take the PCM as well. It will save lots of time down the road when you attempt to tune the engine. I'd verify that the scoupes transmission can handle the torque of the elantra engine just to be on the safe side. That's providing that the scoupe turbo 5 speed is the same transmission for the non-turbo engines, it should suffice as it's good for at least 123ft lbs of torque! Good luck.
Old Jan 16, 2007 | 01:20 PM
eyeruk1's Avatar
Default RE: upgrade
Hey Buddy thanks for the advise, if there are any thing more to look out for please let me know. I live in Trinidad in the West Indies for your info. chat with you soon.
daesimunda
Feb 19, 2008 12:12 PM
ravisher78
Oct 29, 2007 11:08 AM
ski.scott
May 17, 2007 12:41 AM
gerardodp
May 15, 2006 02:43 PM
Polymer_fallen
Feb 14, 2006 10:01 PM
