Vibrating
Old Oct 13, 2018 | 07:56 AM
James Perry's Avatar
Default Vibrating
Hello.
I have a issue with something under the dashboard is vibrating whilst driving. I have found out that it is more audiable if I travel at 50km/h but it can start at anytime like when I just start the engine and start moving.
Things I have tried:
Made sure all tires are pumped up to the max and checked for wear (which there is none).
Removed all loose objects such as paper and coins from the front of the car.
James
​I30 crdi diesel 2010
Old Oct 13, 2018 | 09:30 AM
allegretto's Avatar
When something is vibrating "under the dash" it is probably something loose under the dash. You may put your contortionist skills to use and lay on your back into the footwell. Use a head light and look up there, touch everything you can reach and push, wiggle, pull to find anything loose.
You could also remove the lower panels of the dash etc.
Good luck!
Old Oct 18, 2018 | 02:40 AM
Just to update .. The issue seems to have disappeared, not sure why.
Karpov
May 21, 2016 02:07 AM
krawken
Jul 29, 2011 11:04 AM
Rhondas
Jan 21, 2009 07:30 AM
tibgirl03
Jun 27, 2007 08:26 PM
okdeal6905
Jan 8, 2007 06:03 PM
