(2002 accent 1.5) water pump pulley removal (cylinder head removal)
Old Mar 20, 2013 | 11:16 PM
zainecurtis's Avatar
Default (2002 accent 1.5) water pump pulley removal (cylinder head removal)
im removing and repairing or replacing my cylinder head on my accent. im to the point that i need to remove the coolant pump pulley from all of my research i do not need to remove engine on the 1.5 but i am not able to get access to the bolts on the pulley due to the half to one inch gap inbetween the side wall.. what can you guys recommend that i do in order to remove this pulley and also if you have done this before what other issues may i run into that you have advice on. thanks for your time!!
Old Apr 5, 2013 | 02:34 AM
Default any help or info??
anyone
pennie
Sep 10, 2013 08:15 AM
Kim
Apr 14, 2010 08:29 AM
charliebird333
Mar 30, 2010 08:51 AM
speeder
Mar 9, 2008 07:05 PM
kaosvarkas
Nov 28, 2006 09:52 PM
