2013 Accent start problems
Old Oct 1, 2015 | 07:01 PM
jkp's Avatar
jkp
Default 2013 Accent start problems
My daughter has a 25K Accent that we recently bought used .... obviously still under warranty, so I am trying to understand any common problems this year/model might have before I take it to the dealership.
Recently it would not start ... (all normal dash lights) would not crank .... tried again several times, then eventually it started normally .... happened again today but took approx twenty attempts before she started up.
Battery and connections check out
Any issues with the ignition switch itself, or the ECU (computer) ?
Thanks very much
JKP
Old Oct 2, 2015 | 01:41 PM
avisitor's Avatar
Not cranking??
That sounds like a starter issue or bad grounds
When it fails to crank, check to see if there is battery voltage at the starter
Follow the cable from the B+ (positive) battery to the starter. Should be 12 volts
Check voltage drop from B- (negative) battery to engine block. Should be less than 0.7 volt
If voltage checks out then it probably is the starter
If the voltages do not check out then repair as necessary
Old Oct 2, 2015 | 05:47 PM
jkp's Avatar
jkp
Great reply thanks ! That sounds simple. Would it be common for a starter to work perfectly 99% of the time and occasionally act up .... ?
Old Oct 2, 2015 | 10:03 PM
avisitor's Avatar
Failure modes of electrical components can go from instant and complete failure to working intermittently or failing intermittently.
Aubrai
Aug 26, 2013 08:59 PM
strokercrate
Aug 13, 2013 08:46 AM
JLeon0122
Jun 7, 2013 10:57 AM
benjamincillo
May 23, 2013 12:52 PM
polzohoho
Nov 23, 2012 06:55 AM
