Accent Died Suddenly
Old Dec 14, 2017 | 05:32 PM
rcull's Avatar
Default Accent Died Suddenly
2004 Accent 1.6.
Running, then suddenly quite dead.
I borrowed a scanner and it showed:
P0037 B1S202 Heater Circuit Voltage Low
P0036 O2 Heater Circuit B1S2
P0340 Camshaft Position Sensor Problem
P0650 MIL Control Circuit Malfunction
I expect the Heater codes are unrelated to the problem and I replaced the Camshaft Sensor but it still did not start
So I cleared codes and cranked it again to set a fresh set only the order changed:
Could a timing belt throw these codes?
Thanks
Old Dec 14, 2017 | 06:57 PM
hyundresc's Avatar
What year? how many miles on it? If it's a new car the timing belt shouldn't malfunction that early, in my opinion.
Old Dec 14, 2017 | 07:14 PM
avisitor's Avatar
It sounds like a wiring issue
The cam sensor can prevent start up
Since you have already changed it
Would suspect that it is the wiring
Check to see if there is any frayed wires
Then check schematics to see if anything else is on the same circuit
If it is then disconnect it one by one to see if engine will start
Accent? Seem to remember the old windshields would leak
Old Dec 15, 2017 | 05:38 PM
rcull's Avatar
Unfortunately, it turns out to be a timing belt problem
I understand that this is an interference engine. I suppose that means I have a bunch of bent valves? Do I have any hope?
Old Dec 15, 2017 | 06:26 PM
avisitor's Avatar
Do you have any skills in fixing engines?
If not then there is no hope.
If you do then I would just buy a new timing belt and stick it on and hope for the best.
Probably won't do much good.
Old Dec 16, 2017 | 12:31 PM
rcull's Avatar
Yes, I think I will put the timing belt on far enough to do a compression test, which I expect it will fail, but at least I will know which cylinders have bad valves. Then I will do a job I would rather not.
DodgeCummins98
Sep 9, 2011 11:28 PM
rcdriver11
May 18, 2009 09:52 AM
luvmycarbut
Nov 2, 2008 10:26 PM
cas234
Jun 22, 2006 03:47 PM
spayne2
Dec 28, 2005 05:06 PM
