Can't get engine out (accent)
Old May 14, 2007 | 09:20 PM
jchait's Avatar
Default Can't get engine out (accent)
Hi everybody,
I'm trying to swap 1.5L 12 valve engine on my 1998Hyundai Accent. The engine is on the hoist and as far as I can tell is ready to go out.
It is actually separated from the transmission (automatic) by about 1/2" you can actually see the flywheel. But the crankshaft pulley hits on the body.
Do I need to take this pulley out?. Do I have to loose the transmission?
Thanks in advance.
I have taken out other engines on the past, but Chevy's 350 on rear wheel drive cars. But this is the first time on a transverse front wheel drive.
Thanks in advance
Jaime
Old Jan 29, 2008 | 10:20 PM
fluffypinkkittey's Avatar
Default RE: Can't get engine out (accent)
yes. 99% of teh time with transverse motors you have to remove teh trans. ^_^ i did it on my mk3 jetta, with a 2x4 and a 99 cent strap wrench. it is the proper way to do it. ofcourse. there is always that 1%... that usually ends up breaking something.
Old Jan 29, 2008 | 11:08 PM
ken99's Avatar
I'm not that familiar with the 98 Accent, but most engines on newer front wheel drive cars are dropped out the bottom with the tranny attached on a sub-frame. Once the half-axles are removed and the wiring and cables are disconnected, it usually only takes the removal of four bolts and the subframe can be lowered on jacks or with a hoist. Taking the engine out the top may be the hard way to go.
Old Jan 30, 2008 | 02:19 PM
madindian1's Avatar
all you have to do is remove the crank and water pump pulley. don't loosen trans mounts.
ritchep
Feb 28, 2012 06:47 AM
Arkov
Jan 22, 2011 08:38 PM
mikeb68
Mar 22, 2007 02:34 PM
Dirt
Nov 5, 2006 05:36 PM
rpa11
Feb 12, 2006 12:52 PM
