Charging system malfunction
Old Sep 28, 2019 | 05:31 PM
tjdaniel's Avatar
Default Charging system malfunction
Hi, I recently replaced the alternator and belts on my 2009 accent. Upon starting the car the voltage on the battery reads at 11.8. Once i rev the engine above 2500 rpm the voltage at the battery spikes to 16. The voltage stays at 16 even when idling. The battery tested 599/600 CCA and has 12.4 volts when the car is off. I removed the alternator and had it tested at advance. It tested good. It is a re-manufactured alternator. Any ides as to what would be causing this? Also, the battery light comes on when i start the car and turns off once revved above 2500 RPM. The lights also flicker when the battery voltage is reading at 16 volts.
Old Sep 28, 2019 | 07:24 PM
avisitor's Avatar
It is either a bad alternator or one that doesn't work proper in your vehicle. Get a replacement.
Old Sep 29, 2019 | 05:32 AM
I;ll second that one !
Jamie
Sep 30, 2018 01:49 AM
brian1955
Jan 10, 2018 03:09 PM
Cknittel1
Mar 10, 2017 05:38 PM
surfsk869
Oct 17, 2010 11:08 PM
RMARK
Apr 30, 2009 09:45 AM
