Cruise control done
like the title says, it's in. it was a pain in the ***, some **** didnt work the way it was supposed to, but i love to ghetto rig. either way, it is working now, if anyone else wants to put the audiovox ccs-100 in their car i would be willing to do a writeup on exactly what to do. also the CC servo is mounted to the hood, i giggle alittle every time i see it.
Hey seiken, I have an 08 Accent and I am trying to install the ccs-100 cruise control unit. I have the unit in, I have the blue wire hooked to the negitivewire coming off of the #1 coil. The gray wire is hooked in to the vss where it goes in to the fusebox in the engine compartment. I did the LED check and that's good. I've messed with the dip switches and I still cannot get it to work. Any help you can give me would be great.
Thanks
Mark
Thanks
Mark
I am interested in how you are hooking the control cable to the throttle. I'm installing a Rostra cruise control and I'm stuck on the best way to anchor the control cable to the throttle body area. I mounted the unit on the passenge side strut area, but you need to be able to secure a cable end near the throttle connection. Anybody have a pic of theirs? Thanks
