despretly need help
Hey everyone im in desprete need of help im almost a grand deep on a clutch problem on my 2001 hyundai accent manual, does anyone have any suggestions the clutch is slipping quite badly ive replaced the whole clutch kit,master cylinder and slave cylinder and still havent fixed the problem any help would be awsome cheers
I suggest going to a REAL, TRAINED mechanic.
It sounds like you may have a defective pressure plate !If the flywheel was in good shape when they replaced the clutch there is little else that will cause it to slip ! Oil leaking onto the clutch will make it slip but if you had a oil leak they should have told you about it and fixed it before installing the new clutch!
I have never seen a clutch master or slave cyl. cause a slip problem,this is a "pull type" clutch meaning the release brg. pulls the pressure plate to disengage the clutch if the master or slave were bad you would have problems putting the car in gear.
It does sound like you need to find a better shop
