Help P0722 on 2008 Accent
What trans is in your vehicle?
Most output speed sensors are on the rear of the trans.
Good thinking checking wiring and connections before jumping to conclusion of defective speed sensor.
If you had a simple multimeter you might be able to see if the sensor is putting out any signal at all before replacing.
All the code is telling you is, the computer is not seeing any signal.
