Anyone have an 02 accent and changed the timing belt?
I'm trying to change the timing belt and tensioner. I have no idea on how to get the spring back on. I can't believe no one on the internet has no problem getting the spring back on. Has anyone ever replaced there tensioner on their 02 accent.
RE: Anyone have an 02 accent and changed the timing belt?
didn't noticed that you removed the spring, sorry, did you remove both 12mm bolts already? if so install the 12mm on your left first then try to install the second one on your right afterwards.
04prixgt04
07-10-2011 10:44 AM
Robert
10-19-2008 11:08 AM
marcsyl
09-21-2008 02:52 PM
