Hyundai accent 2010 loud noise and smoke
Old Dec 15, 2021 | 11:02 AM
Carpersondude's Avatar
Default Hyundai accent 2010 loud noise and smoke
Hey everyone, while driving my car today there was a puff of smoke from under the hood. The engine is making a much louder noise while driving, and i could also hear other noises from the front of the car. I replaced my serpentine belts a few weeks ago, which would be the only thing on the car thats different.
Old Dec 15, 2021 | 11:19 AM
If you were able to replace the belt, I would think you should be able to do a visual inspection and see just what changed.
If you changed the belt out of the goodness of your heart, then we need to start at the beginning. If, however, you changed it for a reason other than goodness, that should help guide you to a more specific area. What was the reason you decided to change the belt?
Things that could cause a belt to burn and break,
seized bearing on A/C clutch assy, power strg system anything the belt goes over and rotates is suspect at this time without actually looking at it.
Check the tensioner brg.
Old Dec 15, 2021 | 12:12 PM
I changed the belts due to the fact that they were squealing in the morning of winter months. I just went out to look at the belt and tensioner and everything looked fine.
I took a video of the noise
Old Dec 16, 2021 | 08:03 AM
The ONLY WAY to check the tensioner is to remove the belt, rotate the pulley and listen AND feel for any toughness.
I hope you did this when you say you looked at it an it is fine , Yes/ NO ????
luvdodge
Feb 13, 2014 06:33 AM
CAW
Jun 12, 2012 03:54 PM
elk1
Sep 13, 2011 08:50 PM
SocalXG
Apr 20, 2011 06:40 PM
misstibs
Jan 3, 2005 11:40 PM
