killing ignition coils
Old Jan 30, 2007 | 03:46 AM
accent0002's Avatar
Default killing ignition coils
On my 2000 accent it keeps burning out coils ive replaced both of them a few times and its also burning my pocket anyone know what could be wrong?
Old Nov 10, 2007 | 08:28 PM
clintmeister's Avatar
Default RE: killing ignition coils
Heat kills coils. I had similar problems with the honda's doing the same thing's. Another tip, run multiple ground straps off of the negative side of the battery. Test's have shown about a 4 HP increase. The HP increase comes from the ground having a easier time getting to the motor to make a good spark. Check your ground straps to the motor, you might be suprised. Good luck. Clintmeister
Old Nov 10, 2007 | 09:03 PM
Doohickie's Avatar
Getting a better ground is a good idea, but "Test's have shown about a 4 HP increase" sounds an awful lot like a marketing line from a ground wire seller. Also, make sure all your connections are good.
poch
Oct 16, 2010 09:13 AM
powercoll
Jan 23, 2007 03:15 AM
Jeannettette
Jan 23, 2007 01:45 AM
nebur
Jan 22, 2007 08:35 AM
DSeries
Feb 1, 2006 03:44 PM
