Loud engine noise 1.6L
Old Nov 29, 2010 | 12:46 PM
kalvick13's Avatar
Default Loud engine noise 1.6L
Hello, I am new to the forum but would like some help. I have a 2001 Accent 1.6L DOHC motor. I have had a loud noise from the engine whenever it is on for a while now. Hyundai told me I had a cracked Exhaust manifold and they wanted $1500 to do the work ( Recall for 96-00 models). Well i finally found one and put it on and the noise still exists. The manifold i took off was cracked but I do not see any other holes in the exhaust system after starting the car and crawling all up underneath it. It seems when i let off the gas when driving that it lets off excess air pressure as well. Any ideas?
Old Dec 9, 2010 | 04:06 PM
cabral75's Avatar
sounds to me like it might just be an exhaust leak all together
Old Dec 14, 2010 | 12:04 PM
kalvick13's Avatar
Default Fix
I ordered a whole new front ( FLex) pipe and installed it. That was the problem. It is hard to tell if the flex is broken untill the cold weather showed me the leak.
Old May 4, 2019 | 06:35 PM
Lisa King's Avatar
Default Hyundai accent 02
Hi im new to this.i have a 2002 hyundai accent hatchback manual.ive noticed that when i start the car it makes a knocking noise.i have checked the belt the oil and i cant work out what it is.being a female i dont have tools.can someone help me please.
Old May 4, 2019 | 08:16 PM
Hi Lisa
There could be many reasons for unusual noises coming from an engine.
Your best bet would be to have a good shop or dealer at least check your vehicle before it gets much worse.
Some were involved in a recall for debris left in the engine and required engine replacement. Depending on what the noise is coming from will have some bearing on what steps need to be taken.. I wouldn't wait to have this checked out ASAP.
mvftw
Nov 17, 2014 01:45 PM
riebe
Jun 28, 2013 03:25 AM
illusion321a
May 17, 2011 12:42 PM
ddown
Apr 5, 2008 08:07 PM
GaiaForce
Oct 8, 2007 09:50 AM
