problem with starting
Old Oct 28, 2008 | 02:33 PM
wingover's Avatar
Default problem with starting
Hi all,
I have a weird problem with a 1995 automatic Accent.
ONLY in the winter whenI drive the car in the morning,I usually make 3 stops (turn engine off)to pick up people (strat again)and than drive for few minumts to the final stop. I than park the car.
WhenI come back after an hour the car won't start (engine turns fine), I sometimes have to wait 20 minutes before it starts.
After,I drive it and everything is fine, it will start with no problems even if I turn it off.
HELP?
Old Oct 31, 2008 | 03:44 AM
jsinton's Avatar
Banned
Default RE: problem with starting
I would start with the obvious stuff first. Replace the spark plugs, the air filter, and the fuel filter. It might not help, but it will rule that out and it would be good for your MPG. If you do all that and the problem still occurs, then I would suspect some wierd electrical problem that only occurs when the part in question reaches a certain temperature, possibly a wiring harness or a relay.
Old Nov 2, 2008 | 09:39 PM
SHOZ's Avatar
Floor the gas when it won't start. Might be flooded. Flooring it when starting should turn off the fuel injectors.
rosie
Aug 26, 2020 03:33 PM
vinuge
Nov 30, 2007 09:21 PM
Wolf359
Jun 18, 2007 02:31 PM
martinv
May 17, 2006 01:28 PM
sexysuzy
Mar 23, 2006 06:58 PM
