Hyundai Atos Predominantly sold in Europe, the Atos is the smallest of the Hyundai lineup offering European sub-compact styling.
oil drain and radiator drain needed
Old Feb 14, 2009 | 02:33 PM
danieleonharper's Avatar
Default oil drain and radiator drain needed
need to flush the 2 radiator via tube? any? tap water and coolant replacement?
oil plug to dran where?
got sludge on oil cap and bit of oil in overflow coolant tank so need to check not cylcinder head
oil level too high so hope was that
thanks
Old Feb 14, 2009 | 05:48 PM
jsinton's Avatar
Banned
I don't think I recommend advising you if you do not know where the oil drain plug is. It sounds like your head gasket is leaking anyway. Oil in the overflow is head gasket.
Old Feb 20, 2009 | 10:20 AM
found the drain easily and head gasket was not blown
just need the radiator drain plug now else will remove bottom hose
Old Mar 18, 2009 | 03:11 AM
70Cuda383's Avatar
I'm sorry. I don't understand what you are asking--your garbled sentence structure and mis-used words make no sense...
oil in the water is either blown head gasket, cracked head, or a cracked engine block.
If you're having trouble draining water from your radiator...how did you check your head gasket?
the ONLY way to do it is to pull the head off.
you could try a compression check, but if the head gasket is sealing around the cylinders just fine, but leaking between a coolant and oil passage...that won't show up on any diagnostic check other than to remove the head.
--you COULD do a pressure check on your coolant system, which will only tell you if it holds pressure or not. it will NOT tell you where the pressure is leaking from, so you still won't know if it's a cracked head, blown head gasket or cracked engine block.
riebe
Nov 29, 2012 10:58 AM
HeidiJenkins
Nov 10, 2011 10:18 PM
thx1971
Jun 17, 2009 07:19 AM
bensontom2
Oct 31, 2005 07:08 PM
syncmaster
Feb 21, 2005 07:47 PM
