2013 Elantra Not Starting
Old Sep 3, 2016 | 03:57 PM
ElGordo0524's Avatar
Default 2013 Elantra Not Starting
I have a 2013 Elantra with 55k miles on it. When I try to start it a few times in the past few days it will not engage the starter. It acts as if the battery is dead. Tested battery and it is fine. I am pressing the brake as normal and the shifter will not move out of park either. Then, after it sits for a few minutes, everything will work fine and the car starts fine. This is happening when it is hot out and the car has been driven for awhile. I also notice that once it does start, when i shift into Reverse, it is fine. When I shift into Drive it bangs into D harder than normal.
Any ideas????
Gordon
Old Sep 4, 2016 | 07:41 PM
Recall on the brake light switch on the brake pedal. That could be the cause. Get it looked at. More info: https://www.hyundaiforum.com/forum/g...e-lights-6251/
Old Sep 8, 2016 | 10:53 PM
avisitor's Avatar
Sounds like the park/neutral safety switch is not functioning properly
Or, the linkage to the gear selector is loose.
But, the easiest thing to do first is to check the brake light switch
Old Sep 9, 2016 | 12:32 PM
Default Solution Found
I ended up taking it in once I realized I was still within the 60k warranty
The Inhibitor Switch on the transmission was bad. They replaced it and so far, she starts like normal.
GJ
rosie
Aug 26, 2020 03:33 PM
Atik Barni
Feb 9, 2020 01:53 PM
baurebu
Nov 12, 2012 09:54 AM
Dhiraj
Aug 15, 2008 03:31 PM
joey
Aug 17, 2007 01:46 PM
