Elantra 2013 cruise control not engaging
Old Dec 15, 2015 | 10:52 PM
Atik Barni's Avatar
Default Elantra 2013 cruise control not engaging
Hi friends,
I am happy to be a member of this forum as lots of experienced hyundai users are here in this forum.
I am having a problem with my cruise control perviously there was a issue with my airbag light on and the service center told me my clock spring is malfunctioning and he suggested me to change the clock spring to resolve the airbag symbol issue and he told its related with cruise control.
I changed my clock spring but still cruise control is not engaging and when they checked by their software it shows no error now suggest me what can be the problem as they are unable to solve it...
Old Dec 16, 2015 | 11:12 PM
avisitor's Avatar
Well, if there was no cruise control problem before changing the clock spring
Then if may be a bad clock spring that they put in or they did something wrong to mess up the cruise control
If it is still under warranty then have them fix it right (on their dime)
Old Dec 17, 2015 | 12:02 AM
Atik Barni's Avatar
The problem was also before changing the clock spring and now still the same error. No resolution
Old Dec 17, 2015 | 08:27 AM
avisitor's Avatar
Assuming that they put in a good clock spring and the controls on the wheel are good,
that means the cruise control unit or the wiring has the problem.
Does the cruise control light on the dash come on when you turn it on?
Old Dec 17, 2015 | 09:54 PM
Atik Barni's Avatar
Yes the light on the dashboard turns on when I press cruise but it not blinks when I set it on any speed and not engages...
Yesterday they replaced the steering column with steering wheel but still same problem
Old Dec 18, 2015 | 09:54 AM
Do your brake lights work? I ask because there is a recall on Hyundai brake light switches (on the brake pedal) and if the switch is bad, the cruise control will not work because the cruise uses the signal from the switch to know to disengage cruise if you press the brake. So a bad signal from the switch will prevent the cruise control from setting.
Old Dec 18, 2015 | 11:44 AM
Atik Barni's Avatar
Yes the break lights are working well. They told me to leave the car for a week in their service center so they can check the wiring points after downloading the circuit diagram and service manual
Old Feb 8, 2020 | 04:31 PM
Stafford Sanpei's Avatar
Originally Posted by Atik Barni
Hi friends,
Believe it or not . When I pound on my horn a couple times. The cruise control does work, but only the cancel button doesn't work. What's the prolem?
Old Feb 9, 2020 | 06:18 AM
Will it cancel when you apply the brakes ?
Old Feb 9, 2020 | 01:53 PM
Yes it does
rjh1
Aug 21, 2019 03:54 PM
akaTink
Aug 18, 2011 02:18 PM
Herrmann22
May 3, 2007 09:29 AM
Joe Guit
Oct 7, 2006 11:24 AM
Joe Guit
Oct 5, 2006 07:44 PM
