2013 Hyundai Elantra: Crank, No start, No Codes.
Scenario: My car fired up No problem a few days ago. Today it cranks, no start, and codes found with scanner. I can hear the fuel pump turn on, battery is good, nothing wrong with fuses. I checked the spark plugs and they were wet with gasoline. I cleaned them up check for spark and at first some would spark but then seemed to not light up during cranking when I took them out individually. So it is getting power, fuel, no spark. No codes are in the ECM. I was thinking either coil packs or crank sensor. It seems like it is close to starting then just won't and the next crank is just as bad if not even more fruitless. Any help would be great. No lights come on the dash either.
