2021 Elantra stuck in “ accessory mode “
Old Feb 19, 2022 | 07:49 PM
kristyann6@gmail.com's Avatar
Default 2021 Elantra stuck in “ accessory mode “
Has anyone had this issue? My car will not start and i believe it is in “ accessory mode “ what can i do?
Old Feb 20, 2022 | 08:18 AM
First , what causes you to believe it is in accessory mode?
I have not yet come across this type problem, but do you know how to remove a battery cable?
Old Apr 30, 2022 | 08:24 PM
Lowkey2013's Avatar
Someone had similar issues couldn't turn key off or remove key don't know if they fixed problem or not. Not to insult your intelligence or anything but have you tried moving the steering wheel and moving the shifter
Old May 1, 2022 | 12:45 PM
Pretty sure we are dealing with a push to start system so no key physically required just the remote for the vehicle to recognize..
I suggested removing a battery cable (negative one) from the battery. Sometimes this will allow the system to reset.
In the owner's manual are some directions that may provide an answer for you.
Of course there are some requirements that must be followed like the brake pedal must be depressed for the engine to start.
If it is in accessory mode , you might need to push the start button several times to get it out of accessory mode.
Al B
Feb 24, 2022 10:54 AM
Occulus
Jun 19, 2021 02:58 PM
Sam_XG350L
May 9, 2013 02:01 PM
tabsonata
Dec 12, 2007 02:46 PM
buddlake07828
Sep 28, 2006 02:15 AM
