Brake Pedal Stiff When Starting the Car, but Car Runs Well Afterward
Hello, everyone.
I leased a 2021 Hyundai Elantra in April 2021, and as of this writing, it has less than 7,000 miles on it.
I’m experiencing something that I’m just a little concerned about. May I tell you about it? It involves starting the car.
When I start the car, I press lightly on the brake pedal, and then press the ignition button. I never had a problem.
The past couple of days, though, whenever I start the car, the brake pedal has felt tight. It is rigid, as if it is resisting my foot. I am, however, able to press on the brake pedal and start the car.
Once the car starts, I have no problems with it whatsoever—at least, so far. The brakes work fine, I stop fine, there are no warning lights on the dashboard, and there is absolutely no fluid whatsoever of any kind under the car.
I live in central New Jersey, and we’ve had a pretty nasty heat wave the past few days. Saturday and Sunday we hit 100. Today was a bit cooler, but I still had resistance with the brake pedal when starting it.
I’m wondering if the problem is due to the heat. I made an appointment with the local Hyundai dealer where I leased the car to have it looked at, but they are booked until Saturday.
So…I was wondering if anyone has had a similar experience, and if so, what caused it? Or, is anyone familiar with the issue? Is this a known, common occurrence with Elantras?
Thank you for any feedback you care to give. J. Danniel
Hi Dannie,
From what you described , to me , it sounds like the system lost all the vacuum assist and until the engine is started and vacuum is built up again , the brake pedal has no vacuum assist. Just speculation without actually checking physically. If you would , please let us know what the shop found , thanks.
Thank you for your response. Is what you described dangerous, or a safety hazard? I've had no problems driving. No issues with the brakes, no issues stopping, no warning lights on the dash. No fluid leaks of any kind.
Thank you. Jd
Thank you. Jd
jonyorker
Nov 4, 2016 10:07 PM
Greent8119
Sep 23, 2011 12:35 PM
