Help with 2010 Elantra rear brakes
Old Sep 2, 2019 | 06:38 PM
DanDaMan's Avatar
Default Help with 2010 Elantra rear brakes
My son bought his first vehicle a few weeks ago with is a 2010 Elantra. The brakes started to make a grinding noise. I removed the front wheel and saw the pads almost new. So I removed the rear wheel to find the rear is just a drum system - it has no caliper - just a drum brake. I can't get the drum off though. I searched google and youtube, and everything I could find is the rear should have a combination of drum (for the emergency brake) with a caliber for basic braking - but again I only have a drum system on the back.
First question - is that normal/stock to have just a drum rear back brake? Second question - any advice how to get the drum off - I smacked it many times with a hammer but it is not budging - I also looked to see if the front of the drum has a hole to be able to adjust the tension of the pads but there is no hole like that - the front only has 2 smaller holes which I believe may at once had screws but no screws there now?
Any advice would be appreciated.
Thanks
Old Sep 3, 2019 | 07:01 PM
avisitor's Avatar
Just a thought ....
When there is no hole for adjusting the brake shoes on the drum, may be look for them behind the back near the bottom???
rizzeler
Mar 10, 2018 04:25 PM
IcantDo55
Sep 8, 2015 08:02 AM
jmelantra
Nov 30, 2011 06:59 AM
FiremanBob
Feb 1, 2011 11:22 AM
mmbrady59
Sep 21, 2006 04:21 PM
