Hi everyone
Old Oct 24, 2010 | 05:07 PM
rmani's Avatar
Thumbs up Hi everyone
Hi guys. I'm new to this board. I finally joined because I've had a 2006 Hyundai Elantra 5 speed since new, and it now has about 120k miles on it. It's been a great little car and I envision putting close to 200k miles on her before moving on to something else, but I'm in need of some maintenance.
The clutch and brakes need to be replaced, and I am going to have a friend of mine do the work for me, but I need to order the parts. I have no idea where to go to get these things and exactly what I need.
I need a new clutch, so is there a comprehensive kit I can buy?
What about the brakes? The car needs 4 new rotors and pads and I'd like to buy a full kit for this as well, something that has everything I'll need so my friend can come and do the work for me. Obviously cost is an issue which is why I came here, as I've always found forums to be a great way of finding the best deals on products. So can someone help me out?
Thanks for the help guys!
Old Oct 24, 2010 | 07:26 PM
Welcome. Has the timing belt ever been changed? It should be changed every 60,000 miles. If it hasn't or if you don't know, get it changed ASAP. Or else this could happen:
https://www.hyundaiforum.com/forum/s...ead.php?t=6033
https://www.hyundaiforum.com/forum/s...ad.php?p=32089
Old Oct 24, 2010 | 07:42 PM
rmani's Avatar
it was changed once at 60k miles. thanks for the reminder i'll add that to the list.
Old Oct 24, 2010 | 08:14 PM
Buy your clutch parts from your local dealer, disc, pressure plate, release brg, and (3) of the 75/85 GL M/T oil... DO NOT USE GL5 gear oil, you'll ruin the trans.
Brake parts, local well stocked auto parts store will cut cost there for you.. get some good pads, Wagner Thermo-Quiet from Advanced or O-Reilly be good way to go, RAYBESTOS Ceramic another good choice.. Hyundai pads if nothing available right off.. Dealer always has pads & rotors, just have to put up with their mark up, but our pads average $65 per axle set in most cases.
While you gots the trans out, pop the hose off the slave, and remove the spring loaded restrictor thing inside there,, your clutch will last longer, and flush the release system so it has new clean fluid... wipe the black mud out of the resevoir.
Old Oct 24, 2010 | 11:16 PM
rmani's Avatar
what about this clutch? I've been ripped off by dealers so often I honestly try to stear clear of them.
http://www.autopartswarehouse.com/de...e&apwidwRtFxd6
Old Oct 25, 2010 | 09:07 AM
Hyundai OE parts :
(1) -- 41100-28060 DISC ASSY-CLUTCH $150.54
(1) -- 41300-28031 COVER ASSY-CLUTCH $98.10
(1) -- 41421-39000 BEARING-CLUTCH RELEA $63.44
(3) -- 08950-00020 MTF-MANUAL TRANSMISS $52.05 (TOTAL)
Old Oct 25, 2010 | 09:43 AM
rmani's Avatar
Originally Posted by sbr711
Hyundai OE parts :
would i have to order all of these just to replace the clutch? What if I bought this kit would it be better?
http://www.autopartswarehouse.com/sk...%26+Drivetrain
or what about this one? http://cgi.ebay.com/ebaymotors/NEW-C...#ht_2333wt_933
blowneardrums
Aug 2, 2006 06:10 AM
consumer affairs
May 29, 2006 11:36 PM
Joe//2000Elantra
Apr 4, 2006 10:24 AM
poacher
Dec 20, 2005 09:36 PM
mbtec
Dec 9, 2005 12:28 AM
