Driving Lights?
Old Jun 27, 2010 | 04:10 AM
Ranger524's Avatar
Question Driving Lights?
I apologize if this was already asked but I didn't see anything. I have a 2010 Touring GLS model that does not come with the lower driving lights. I would really like to have the OEM lights installed. Does anyone know if this can be done? I know that there is a question about the switch, the switch in the SE model is in the head light control lever, but I'd be willing to just have a switch put in the open spot I have next to my esc switch.
Thanks
Old Jun 27, 2010 | 09:19 PM
tub's Avatar
tub
fog light?
Old Jun 28, 2010 | 03:10 AM
Ranger524's Avatar
fog/driving lights, the 2 lights in the lower front bumper.
Old Jul 3, 2010 | 05:22 AM
DrDemento's Avatar
Yes, it can be done. As for the location of the switch should be perfect. Remember to tie the electric to a relay and have the power to the relay series to the relay coil. Do not tax any circuits.
In other words the main power from the battery to the contacts of the relay, The coil to your switch and the coil power from the off line power circuit of the key.
These lights if left on will drain your battery very fast.
Old Jul 3, 2010 | 04:55 PM
Ranger524's Avatar
Thanks for the info DrD gonna see about getting the OEM lights and hook them up. I figure if I have the same wiring harness as the SE model then everything should hook up and the only issue I'll have is for the switch. Thanks Again!
Old Jul 15, 2010 | 08:03 PM
ihbobry's Avatar
You don't. The harness is more or less vehicle specific. There are no extra pigtails (maybe you are lucky and have some taped up but that is really unlikely). You need to cut into the harness, add a relay and a switch. I would not try to ride the low beams.
Bernie
Old Jul 16, 2010 | 05:17 AM
Ranger524's Avatar
Thanks Bernie for the info, If I get the OEM light housings and bulbs is there a certain type of (rated) wiring and relay or will any standard fog light wiring pack suffice?
Thx
Old Jul 16, 2010 | 07:02 AM
ihbobry's Avatar
Thx
NAPA and Hella make kits for the wiring. The oem bulbs will need specific connectors. They are available only as part of the harness I believe. The solution to that is working with a parts store or department to find a plug that fits. I have seen this done on 2010 Sonotas and the plug turned out to be a transmission control connector for a GM pickup. Part Number was AC Delco PT120.
Old Jul 20, 2010 | 08:15 PM
Ranger524's Avatar
Thx Bernie for all the info I will talk with my local autoparts dealer and see if we can come up with something.
Wisconsin-Autocrosser
Oct 18, 2010 10:44 PM
SantaFaer
Oct 7, 2010 10:35 AM
lukehughes
Sep 18, 2010 04:34 PM
woodie101
May 8, 2008 09:21 AM
50btripn
May 10, 2006 02:46 AM
