'03 Santa Fe 2.4L Hesitation
Old Dec 4, 2015 | 11:06 AM
  #11
Brob's Avatar
Default Crank blade?
I recently replaced the timing belt on my '04 2.4 litre Santa Fe and since then the engine "floats" around 2200 rpm while driving. It runs perfectly otherwise. Basically as I'm driving along if the vehicle is running around 2200 rpms the throttle sort of cuts out, not dying, but drops down until I either accelerate or the engine suddenly "wakes up" and jumps back to the original rpm, often with a lurch from the automatic transmission. The engine has good power otherwise and this doesn't happen under hard acceleration.
Originally Posted by hyundai tech
Your dealer should perform tsb# 04-36-017 for hesitation problem.It is a simple download.Other things I have seen are the crank blade behind the timing belt gear cause problems. The crank blade key slot becomes loose and allows the blade to move which causes a hesitation due to crank position.I would start there with the download first.Common procedure that applies to 2003-2004 Sante -Fe.
Old Nov 8, 2022 | 08:15 AM
  #12
raycock48's Avatar
Default Crank position sensor
=Brob;50696]I recently replaced the timing belt on my '04 2.4 litre Santa Fe and since then the engine "floats" around 2200 rpm while driving. It runs perfectly otherwise. Basically as I'm driving along if the vehicle is running around 2200 rpms the throttle sort of cuts out, not dying, but drops down until I either accelerate or the engine suddenly "wakes up" and jumps back to the original rpm, often with a lurch from the automatic transmission. The engine has good power otherwise and this doesn't happen under hard acceleration.[/QUOTE]
sounds like a crank position sensor issue
bigflippa_ny
May 18, 2010 07:59 AM
conorsdad
Jul 31, 2007 11:04 AM
01santafe
Sep 16, 2006 01:03 PM
Jim D
Sep 2, 2006 10:18 AM
distortion_69
Sep 22, 2005 08:27 PM
