2001 Santa Fe ABS issues
New to the Santa Fe's
The following ABS codes popped up, was hoping to get some help solving these here.
C1203 Wheel sensor open or shut
C2112 Main Relay or Fuse
C1604 ECU Hardware error
I replaced both front wheel speed sensors(yep, they were stuck) and no change.
Are these some common issues that creep up on these trucks? any common fix's? Shop mentioned replacing the ECU but could cost $1k or more
2001 Santa Fe GLS w/ 2.7 v6 AWD 101k mi
Any guidance would be appreciated
The C1604 is directing you to the power steering system, possibly involving a torque sensor.
Your best bet is to have a qualified shop with the info and equip to do what must be done.
Guessing can get expensive and disappointing.
the previous owner did say they replaced the pwr steering pump. By torque sensor do you mean Steering Angle sensor?
I did have a mechanic scan it first, he mentioned the code could be to replace the ECU or the ABS control unit(HECU)
Anyone else come across this?
Understanding all that, is there any guidance you have on this issue?
Anyone have experience with this issue, I have read many come across it but have not seen solutions posted?
This is more than you are equipped to handle.
You don't have the tools to correctly diagnose the problem and I have some reservations about the shop you are using.
As suggested earlier, consider taking it to a dealership. They should have all the necessary info, and tools to do what is necessary to correct this.
I can understand trying to find an easier solution, but there is none. There are times we just have to do what is required.
Charlotte72
05-04-2022 05:03 PM
