2005 Santa Fe fuse blowing
Old Jun 13, 2019 | 06:27 PM
JohnRohn's Avatar
Default 2005 Santa Fe fuse blowing
Fuse 28 keeps popping and don’t know why. Here’s what I do know:
1. Lights behind the gauges don’t work (speedometer, tach, gas gauge).
2. Right side marker light doesn’t work
3. Right tail light doesn’t work
4. Fog lights don’t work
5. All other fuses seem to be fine
6. Rear lamp relay seems to be fine
7. Fuse 28 doesn’t pop until I switch on the lights
Anybody have any idea what might be the culprit?
Thanks!
Old Jun 14, 2019 | 08:36 AM
Hi John,
Evidently, there is a direct short circuit path allowing the power to go directly to ground. The idea is to attempt to locate that shorted location.
The possibility of a problem within the dash lights is kinda remote, so let's look at the more likely places.
If no one has worked anywhere on the vehicle before this problem appeared, I would start with opening up the R/S fog light assy and look at the assy plus the wiring to that light. If no broken or pinched wire is found don't reinstall everything just yet, move on to the R/S marker while up there , open it up and do the same thing. If no problem is found there ,go to the R/S tail light and check that out. The reason we don't reinstall everything until the problem is found is because sometimes the problem is not present when everything is removed. If the fuse still blows with all those items opened up ,there is a problem between the fuse panel and the wiring to those lights. Before going any further , let's see what you find up to this point.
picard25
Mar 14, 2017 10:09 AM
llomo000
May 14, 2013 10:03 PM
bchgoer
Jan 25, 2011 08:37 PM
Ricklee64
Jun 8, 2009 05:29 PM
mntbiker2008
Aug 24, 2008 11:45 AM
