2006 Sante Fe tail lights stay lit after brake booster replacement
Old Jun 19, 2023 | 11:36 PM
Advisual's Avatar
Default 2006 Sante Fe tail lights stay lit after brake booster replacement
Hi,
I have a 2006 Hyundai Sante Fe 2.7L 2wd that I changed the brake booster on and now the tail lights stay lit.
Does anyone have any idea of what might be causing this?
Any help would be appreciated.
Thanks
Old Jun 20, 2023 | 09:46 AM
When you state "Tailights" do you mean parking lights or stoplights?
Old Jun 20, 2023 | 09:48 AM
Advisual's Avatar
As if you were stepping on the brakes
Old Jun 20, 2023 | 12:53 PM
There is a rod that comes from the brake pedal and goes to the booster then to the brake master cyl.
On most vehicles that rod is adjustable. If the booster is replaced, the installer must make sure the brake pedal is coming all the way up to cause the stoplight sw to open or the stoplights will stay on. Check that and if that does not correct the problem we can offer another check..
Old Jun 20, 2023 | 01:14 PM
Advisual's Avatar
Hi,
Yes, that was the problem. The brake pedal was not pressing a little plunger. I made an adjustment so that it was pressing the plunger and that fixed it.
Thanks for your help
Old Jun 20, 2023 | 06:11 PM
Thank You for the update !
haw77
Apr 28, 2016 07:37 AM
dglrmn
Jan 12, 2013 09:08 AM
john cheswick
Mar 26, 2012 07:58 AM
libgal
Oct 25, 2011 06:41 PM
frozeh2o
Aug 27, 2006 12:50 AM
