2008 vibrating under acceleration FWD 2.7L
Old 10-06-2018, 11:28 PM
Marchion's Avatar
Default 2008 vibrating under acceleration FWD 2.7L
I replaced all of My sway bar links in the front and a passenger side cv shaft. I replaced the cv shaft because I thought I bent it when I was forcing it over to get the ball joint in. It seems like it got a little worse since I put the new cv shaft in.
it's a wobble starting at 20-40kmh.
thlanks
Old 10-06-2018, 11:32 PM
avisitor's Avatar
It may help if you have someone follow you
And watch the wheels.
It might so what is the problem
Old 03-15-2019, 10:06 AM
allegretto's Avatar
Do a tire rotation first. If the wobble moves with the tires the problem is with the tires or rims.
new28868
07-09-2019 10:38 AM
Rob Curasco
11-19-2017 07:37 PM
jeepster
04-12-2014 06:21 AM
Arkov
01-22-2011 08:38 PM
Dsktsunami
01-04-2011 11:15 AM
Quick Reply: 2008 vibrating under acceleration FWD 2.7L
