HELP Mysterious indicator problem
Old Jan 22, 2020 | 04:29 PM
Matt31's Avatar
Default HELP Mysterious indicator problem
Hi
I have a Hyundai Santa Fe 2008 2.2 diesel
I have a problem which I cannot fix with my indicator. On one side only the indicator is flashing at double speed (like a bulb has blown). The problem started after blowing a maxi fuse? I have taken it to the garage but they cannot figure it out!!
I have tried the following:
  • Changed all bulbs
  • Checked all other bulbs
  • Changed front indicator bulb holder from on side to the other
  • Plugged in the other side rear light
  • replaced the ICM relay
  • adding an extra bulb!! (Knew this wouldn't work but thought maybe increasing the resistance may work)
None of these made any difference. I am not great with electronics so if anyone has any suggestions what it could be or that I could test i would be grateful.
Thanks
Matt31
Aug 22, 2025 10:10 PM
jsolar
Jun 9, 2018 02:45 PM
thedoctor63
May 15, 2018 06:27 PM
daniel2229
Nov 4, 2013 07:27 AM
mn_dude
Mar 31, 2013 07:22 AM
