2006 Sonata_ first oil change?
Old Aug 28, 2006 | 12:10 AM
sahn_hoaklee's Avatar
Default 2006 Sonata_ first oil change?
[size=2]Well I must say as a prevous Honda Accord owner, I will never go back to Honda. But the real question is, I was told by the dealership that you have to get the first oil change there because there is a second paper filter put on while the car is being made, and must be removed during the first oil change. (I think) the dealership said that the second filter was under the valve cover....Is this True? or are they trying to get an extra hundred bucks from me?
Old Aug 28, 2006 | 11:42 AM
fritz's Avatar
Default RE: 2006 Sonata_ first oil change?
It sounds strange since according to your conversation with the dealer, the second filter doesn't needs changing, just removed.
Old Aug 29, 2006 | 12:49 AM
Yeah I thought it was a little stange too that it would come from the factory with an extra filter on it, that just needs to be taken off, maybe it could be a filter just during the breakin cycle but woulded the maintenace log say something about that, and if so then it should be in the contract that the dealership will pay for if to get removed. If anyone has heard of a second filter being ONLY on the 2006 Sonata V6, (I also have a 2006 Tuscon but it didnt come with the Second filter) please reply, because Im baffled in a discion to remove the valve cover to see it if one is really there.
Old Mar 1, 2007 | 10:52 AM
sonatalover's Avatar
I think that they use some sort of cartridge type filter for 3.3l v6
You can get them at the dealer but not at aftermarket
Although I found some on ebay
I'm not sure of the second filter
Old Mar 1, 2007 | 09:59 PM
stingray69's Avatar
Just had my 07 SonetaSE oil changed. No mention of second filter, however
the first oil change was free. Was talking to the parts guy and was advised after
Hyundai sells 1,000,000 filters you'll be able to buy them from the auto parts stores??
http://community.webshots.com/user/46metal
Old Jul 6, 2007 | 07:37 PM
dean08's Avatar
As far as I can remember, on my first oil change it was done with no charge at my dealer... They even removed my second filter for free and they even told me that the factory has some extra Honda Accord performance parts that are installed with no specific function and removing some of them would not make a negative effect with auto processes in my car... I even reviewed my car's specs and I did not found anything about a second filter and the parts that my dealer told me about... Anyway, as long as it will not cause any malfunction on my car.. I'd rather not touch it... Good luck!!!
sdc_bolts
Nov 20, 2011 10:03 PM
appel2007
Jul 30, 2010 08:21 AM
FASST LN
Dec 10, 2009 10:01 AM
anonymouse
Oct 13, 2008 07:11 PM
lutontownfc
Jun 15, 2006 08:59 PM
