Performance rotors
Old 11-03-2018, 10:26 PM
Kevin Palmer's Avatar
Default Performance rotors
I just bought some ebc performance rotors and they will not clear the caliper bracket. Auto said that will fit my 2015 sonata sport 2.4. The rotors are 12.6 I know stock rotors are 11.1. Anybody else run into this problem?
Old 11-03-2018, 10:38 PM
avisitor's Avatar
Can you return the rotors?
If it isn't an on line store then it should be fairly easy to return
If it is an on line store then they will try to convince you that you were wrong in one way or another to avoid taking the return.
Old 11-03-2018, 10:58 PM
It was amazon and, I've seen everywhere that they "fit" but they wont clear the caliper bracket. Was curious to see the biggest anyone has for either the stock brackets
Old 11-04-2018, 09:34 AM
avisitor's Avatar
Call up the seller. See if there is another rotor for your vehicle.
Sankar Subramanian
12-13-2016 10:08 PM
bigmo66
11-11-2014 01:30 PM
timt
07-05-2007 06:24 AM
cbpofficer 9813
08-20-2006 10:07 AM
elantrai
04-25-2006 03:40 PM
Quick Reply: Performance rotors
