2011 Hyundai sonata limited push button problem
Old Oct 23, 2023 | 07:47 PM
Busby 774's Avatar
Default 2011 Hyundai sonata limited push button problem
Nothing happens when button is pressed battery in remote is good and the car battery is good will not do anything when the button is pressed to start the car
Old Oct 24, 2023 | 04:42 AM
What you can try is turn the headlamps on . Are they at full brightness?
Are the stop lights working?
Old Aug 11, 2024 | 06:53 AM
Busby 774's Avatar
no the lights are no working and i have cleened every ground an replaced the battery 3 times \and changed brakelight switch
Old Aug 11, 2024 | 07:58 AM
jbragues's Avatar
Do you have another key fob you can use just to see if the problem is in the key fob itself.?
Old Aug 11, 2024 | 09:08 AM
Busby 774's Avatar
yes and northing it will not comunicate with scaner to re program fobs either since you gotta push the button to put in acc mode
Old Aug 11, 2024 | 10:26 AM
jbragues's Avatar
Sure sounds like a bad receiver on the vehicle not pairing up with your Key fob remote.
Old Aug 12, 2024 | 12:28 AM
Yernaz's Avatar
Check the fuses related to the starting system and ignition, as a blown fuse could be the issue. The starter relay might also be faulty, so consider testing or replacing it. Additionally, the start button itself or its wiring might be defective. If your car has an aftermarket alarm or immobilizer, it could be interfering with the starting process. Finally, ensure that the battery terminals and cables are in good condition and properly connected.
rosie
Aug 26, 2020 03:33 PM
mushj
Jun 8, 2012 09:54 AM
sockers52
May 17, 2011 07:10 AM
UGAgirlyGirl74
Mar 1, 2011 06:07 PM
johnwad
Aug 26, 2010 02:14 PM
