2011 Sonata Limited will not crank/start
I have a 2011 Sonata Limited that is only 3 months old. Never had a problem until yesterday. After lunch I returned to the car and it would not start. It would not even crank over. However, all the interior lights, dashboard lights, power windows and seats worked just fine. I did notice that the headlights and brake lights did not work. Pushing the push-button start acted just as if you did not put your foot on the brake pedal to start the engine. It just turned on the accessories.
I waited an hour for a tow and the driver tried to jump start the car. The first time he tried it still would not crank. The second time it started right up. I drove it directly to the dealership and it has remained there for the past 24 hours.
Has anyone else had this problem? Any suggestions? Could it be a faulty or misadjusted brake pedal switch? How about a problem with the key fob?
Thanks!
Thanks!
Been a load of shifter frames replaced for that, more so on the early production..
PROBLEM RESOLVED!!!
In responsed to my first posting, the dealership found out that it was a faulty brake pedal switch. They replaced and adjusted the new switch and it is as good as new!
Keep this in mind if anyone else out there has a similar problem.
Thanks for your postings. Great forum!
tasseltrader
03-23-2015 05:22 AM
TJCOOK19
09-20-2013 11:43 AM
UGAgirlyGirl74
03-01-2011 06:07 PM
