2016 Sonata Hybrid headlight adjustment
Old 01-21-2018, 02:47 AM
tkerrigan's Avatar
Default 2016 Sonata Hybrid headlight adjustment
Wondering if anybody has adjusted their headlights on a 2016 Sonata plug-in hybrid with HID lamps. I took it into the dealer and they said they are aimed to spec. Well they aren't getting the constant high beam flashes from other cars at night. I think I've seen a few fingers also. I looked on the outside of the housing but didn't see anything likely. I haven't unscrewed the plug where you install the lamps yet to see if there are adjustment screws inside there yet. I will wait a while and see if anybody answers here first. Thanks for any help in advance. Regards, Tom
Old 02-26-2018, 12:04 PM
tkerrigan's Avatar
This car has HID headlights, I wonder if they used regular aiming specs instead of HID. I've communicated with Hyundai twice so far, but haven't had any feedback. Regards, Tom
Old 02-26-2018, 11:07 PM
avisitor's Avatar
Yeah, it has been slow on this forum.
So not too much in the way of answers
I own a 2001 Elantra so I am not much help
Can only suggest looking in a manual or another forum???
Good luck
Old 01-10-2019, 11:10 AM
Eliot Sin's Avatar
I have a 2016 sonata hybrid ltd. Same prob with hids began about a few months ago. Did you adjust?
Old 03-17-2019, 07:46 PM
oragex's Avatar
Hi, not sure if your are the same headlights, but this is how to adjust them in the Limited edition (I believe the Limited has LED headlights)
Old 03-18-2019, 01:15 PM
Eliot Sin's Avatar
Originally Posted by oragex
Hi, not sure if your are the same headlights, but this is how to adjust them in the Limited edition (I believe the Limited has LED headlights) https://www.youtube.com/watch?v=SYW1NXw-5W0
Thanks! I already adjusted mine. Above the toothed wheel that was turned by hand in the video is a funnel. Sticking a Philips screwdriver down that funnel will mesh its tip with the wheel's teeth. Turning the screwdriver turns the wheel like a gear! No mess. When the wheel turns clockwise, the beam lowers.
ata10
08-01-2023 10:50 AM
Bootscooter
02-20-2017 10:44 PM
BAJI16
02-04-2016 02:35 PM
ata10
11-14-2015 08:40 AM
ski.scott
05-17-2007 12:41 AM
Quick Reply: 2016 Sonata Hybrid headlight adjustment
