Azera & Sonata wheels interchangable ?
Old Dec 2, 2008 | 07:49 AM
AdvisorGuy's Avatar
Default Azera & Sonata wheels interchangable ?
I saw a set of 16 inch Azera wheels and was wondering if they'd fit my 08 Sonata.. TIA....
Old Dec 2, 2008 | 09:00 AM
ken99's Avatar
Default RE: Azera & Sonata wheels interchangable ?
Quick answer, yes. Double check to make sure they are 16x7 with a 5-114 bolt pattern. I think the offset should be ~40 mm.
Old Dec 2, 2008 | 03:35 PM
No problem, they will easily fit. Bothare 16x6.5" in size and have the same 5x114mm bolt pattern.
The Sonata wheel has a 46mm offset while the Azera has a have a 38.5mm offset. That's minor andshould cause no problems at all as long as you keep the stock tire size. Each wheel will stick out about 8mm more (1/3 of an inch).
Wisconsin-Autocrosser
Nov 18, 2010 09:51 PM
bryanbuchi
Feb 27, 2009 06:42 PM
idizine
Nov 28, 2008 02:57 PM
oem_motorsports
Apr 30, 2008 12:47 AM
heypal
Nov 12, 2006 02:56 PM
