Leaking fuel Vacuum Module
Old Jan 3, 2011 | 06:12 AM
boggo1958's Avatar
Default Leaking fuel Vacuum Module
I have a 2000 V6 Sonata and over a few weeks have smelt petrol so i checked around and found that a small vacuum line running off the side of the intake manifold to what looks like a vacuum module connected to a fuel line. The line had perished and was squirting out petrol from the vacuum module(but only at start up because i use LPG.so it auto starts on petrol then changes to LPG) Now has the rubber inside perished and what does this vacuum module actually do?? Thanks
Old Jan 3, 2011 | 02:58 PM
It is called a "Fuel Pressure Regulator"... the diaphram is leaking fuel. Replace it before it gives engine more of direct injection and flood motor, either rich or hydro-lock...
Old Jan 14, 2011 | 09:42 PM
Hyundai hauls Ass!'s Avatar
Lightbulb fuel odor
I have a 2000 Sonata also. I just caught a faint whiff of gas a few times so I looked under the car and saw my fuel tank only has one strap holding it onto the bottom of my car. lol. I have been hearing a thumping noise which i thought was the rear driver side shock mount. However, I now think it might be my gas tank banging around instead. Anyway , I thought you might do well to check that out too. I am gonna look at my fuel pressure regulator too.
kconatymd
Feb 13, 2015 03:27 AM
Stamford
Sep 26, 2013 06:49 AM
seized threads
Feb 6, 2011 05:05 PM
kdagenais
Jul 1, 2006 01:14 AM
JGeZau
Jun 26, 2005 06:07 PM
