P0057 H02S Circuit Low Bank 2 Sensor 2
Old Dec 10, 2021 | 07:58 AM
scj6771's Avatar
Default P0057 H02S Circuit Low Bank 2 Sensor 2
Getting the following code with my 2007 Sonata, I believe this is the rear sensor located near the converter? Is this correct? Does anyone have a part number or a link to the part so that I could purchase? Thank you in advance.
Old Dec 10, 2021 | 08:39 AM
Not knowing your level of experience, first get the sensor you might need from Hyundai.
Don't know what tools you have to work with, so we are limited there.
If possible , you might try replacing the mentioned oxygen sensor. Then try clearing the code.
If you read the scan tool carefully it does state,,,,,,,heater CONTROL circuit low. Not necessarily a problem with the O2 sensor.,but the control circuit for the O2 heater.
You might want to have someone with the tools to do voltage testing check out the control circuit.
Are you equipped to do this?
Old Dec 14, 2021 | 08:49 AM
scj6771's Avatar
That's just it, I am not sure which sensor I need, I will not be doing the job myself, I am just looking for the part needed. Thanks.
Old Dec 14, 2021 | 11:54 AM
If you provide your vehicle's VIN (vehicle identification number) to a Hyundai parts dept, they should be able to supply the correct sensor ,,if needed,
Guessing can get expensive and disappointing if the incorrect parts are used/installed.
To answer your question the bank 2 sensor is the side of the engine opposite #1 cyl and AFTER the converter.
I would still verify the control circuit is working correctly before condemning the sensor.
star54
Mar 1, 2015 08:26 AM
racing1219
Aug 29, 2014 06:56 AM
thekid22681
Mar 28, 2012 04:08 PM
bobjenkinssr
Mar 7, 2012 05:51 PM
CTMS2007
Feb 1, 2012 08:57 PM
