Sonata loses power - Limp mode
Old Mar 13, 2007 | 04:33 AM
HyuSon's Avatar
Default Sonata loses power - Limp mode
Hi
I am a new owner of 1999 Sonata. Ever since I have bought it, at least once every two days, the car changes gear with a thud and then it loses all its power. It gets stuck in 3rd gear or so. When I change the driving modes to Reverse the whole car shakes. However, when I switch it off, and start again, the car drives incredibly. I took it to the specialists, but they could not find any code when they connected the scanner computer, though physically they too felt loss of power.
Does anyone know how to fix this problem? Or atleast, the various possibilities of this problem? Thank you.
HyuSon
Old Mar 13, 2007 | 06:02 PM
Doohickie's Avatar
Default RE: Sonata loses power - Limp mode
Do you get a Check Engine Light? If so, what is the code? It could be something relatively simple to fix such as a speed sensor. There are sensors that measure engine rotation, transmission rotation and wheel rotation. If the signals from those get out of sync, the transmission gets confused and goes to a third gear limp home mode.
It could be something more serious, but you need to get it checked. If you get the CEL code read and it points to a specific sensor, you might be able to change it out yourself and save some money.
Old Mar 13, 2007 | 08:10 PM
HyuSon's Avatar
Hi Doohickie
Thanks for your quick reply. Actually, no lights come up when it happens. No codes were found as well.
Thanks.
Old Mar 13, 2007 | 08:33 PM
hyundai tech's Avatar
It is going into 3rd gear limphome due to sensor malfunction.Check codes in Tcm.
Old Mar 13, 2007 | 10:34 PM
Doohickie's Avatar
I think you need to check each sensor. Might have to take it to a dealer for that (or buy one of each).
Old Mar 14, 2007 | 04:55 AM
HyuSon's Avatar
Hi Hyundai tech and Doohickie
Thank you both for your replies. I have taken the car to the dealer. Will inform you what they find out.
Old Mar 16, 2007 | 11:54 PM
HyuSon's Avatar
Hi Guys
The problem was in 'differential speed sensor'. They have fixed it and the car is driving very smoothly.
Thanks
Old Jun 8, 2007 | 01:07 PM
olegna105's Avatar
I also have the same problem. I replaced the input and out speed sensors and still have the problem. Can the differental sensor be purchased and installed from someone other than the dealer?
Thanks
Old Sep 16, 2023 | 01:47 PM
LimpHome's Avatar
Default 2012 Sonata Brake Switch causes entry into limp home mode
MY 2012 Sonata has 188,000 miles on it. The brake light switch plunger, over time, had worn a 3/64 inch deep dimple into the rubber button that the switch plunger rests against. See the picture. The 3/64 of plunger extension caused a partial switch operation. The plunger extension was enough to cause the computer to think that the brakes were on constantly. However, the 3/64 extension of the brake switch plunger was not enough to turn on the brake lights. No engine codes were generated. One morning my wife noticed that one of the brake lights was on. The little rubber button cost $3.00 at online Hyundai parts.
old tbird
Nov 14, 2014 07:43 AM
Sam_XG350L
May 9, 2013 02:01 PM
WoWitsMelvill
Feb 21, 2012 11:11 PM
heather84
Jun 11, 2009 02:41 AM
tabsonata
Dec 12, 2007 02:46 PM
