Transmission problems
Old Mar 7, 2025 | 10:24 AM
andresouza1987's Avatar
Default Transmission problems
Hey guys!
I have a 2007 Hyundai Sonata GLS 2.4 and I have a problem that I can't fix.
I will report the problems and what I have already done, I hope an “angel” who has already had the same problem appears to help me, my head is hot with this car.
1.The gears do not appear on the dash
I replaced the Inhibitor Neutral Safety Switch, tested the lever and it is perfect.
I tested the orange pin and there is no 12v, I made a bridge and so the “D” appears on the dash, but that doesn't solve the problem, I just did it to test the dash.
2.The lever does not release when I press the brake, I can only move the lever if I release the lock manually. I have already replaced the pedal sensor and the brake light works fine.
3.Speedometer not working.
Replaced all 3 transmission speed sensors.
No ABS error, wheel sensors are good.
When I use the scanner I can get speed information.
4.When I drive the car it doesn't change gears.
Has anyone had a similar problem?
My suspicion: TCM/TCU
After changing all the sensors and the problems are all related to information that is processed by it
Thank you in advance!
Dory
Apr 14, 2021 02:29 PM
JamesMc
Jan 16, 2021 05:57 PM
rmnkys
Dec 5, 2017 11:14 AM
sailed2japan
Jan 11, 2011 10:13 AM
rjm727
Aug 27, 2009 09:07 PM
