usb port replacement
If possible can you post a few more pix so I can see where to start opening it up ?
It appears there was a heavy drain or maybe a short in the component.that plugged into that port.
Have you acquired a replacement for that plug yet, if not I would suggest not to do anything until you obtain a replacement.
There is an alternative , however, and that is to get an adapter that plugs into the 12 volt port and has a USB opening made for that purpose.
Broken usb
the white interior part of the current usb is gone so a usb cable cannot connect (has to for Apple play to work)
have ordered replacement usb (OEM) but was looking for instructions to remove the current usb connection (about a 2" square part).
can't find any YouTube videos showing how to take trim off to get to the usb part and replace with new on???? 2017 sonata
thanks
