2005 se v6 6 speed clutch problem
#11
RE: 2005 se v6 6 speed clutch problem
I'm having some clutch problem with a Tib 2003 Gs-r. I need to fight with my shifter each time i want to get out of the first and reverse gear, I have to double clutch, sometime even if my clutch pedal is down, my car is triyng to advance and someting is making noise. I don't know if I should change my clutch system or try to change the hydraulic sytem first? How can I know if my piston is working good or not?
Does someone would have an answer ? Thanks
#12
i bet your throw out bearing is shot/stuck. if your car is advancing while the pedal is down, its either that or your clutch fork is stuck in one place. question though, when you put it in first on take off does it slip if you give it more then half throttle? if so, i'd bet that is the problem, but i wouldnt' know for sure unless i drove it.
gardengirl28
04-28-2009 11:12 AM
speeder
03-09-2008 07:05 PM
mjnor1
10-08-2007 02:34 PM
