Cold Air intake messed up
Old Jul 21, 2008 | 08:40 AM
giacomo's Avatar
Default Cold Air intake messed up
My friend has a 2000 4-cylinder tiburon coupe. He already has had a custom cold air intake on the car which was place around 6 inches away from the engine block and also sat on top of the compartment very close to his carbon fiber hood. He says this intake sucks and takes in hot air, so he buys a new AEM cold air intake that sits very low, right on top of the splash guard. After we put it all in and were all set he starts the car. The car had no power, the intake manifold was very loud and sounded to be sucking in air from a hole but no hole was clearly visible. Smoke was rising from the engine block. A smell of burning grease (i think) was coming out also. Is the carburetor messed up, is there too much air or not enough? Please help
Old Jul 21, 2008 | 10:08 AM
Default RE: Cold Air intake messed up
Where do I start.
First, there is no carburetor. Your friends Tiburon has fuel injection.
Second, the old intake is not a CAI (Cold Air Intake) it is an SRI (Short Ram Intake). SRI's place the filter in the engine compartment. CAI's place the filter outside the engine compartment, usually by the front wheel.
Make sure all the connections are complete and tight. Not just the intake tubing but any wire connections you may have disconnected. If all else fails, re-install the old intake. If the problem goes away, the new intake was the problem. If the problem is still there, there is nothing wrong with the new intake; the problem is with something you messed up while installing the intake.
Old Jul 21, 2008 | 10:27 AM
giacomo's Avatar
i think its an intake manifold leak. i hear a loud hissing sound coming from it, do you know how to fix it?
Old Jul 21, 2008 | 10:48 AM
You have to find the leak. Go over each connection of the intake tubing to make sure they are all sealed.
Old Jul 21, 2008 | 10:57 AM
giacomo's Avatar
okay well, nevermind. thanks for your help anyways. my friend brought it to a shop. he has no sense of adventure. thanks for your help. if i ever to buy a korean car, ill be sure to come to this website.
nateb22
Mar 12, 2010 09:35 AM
jspider27
Apr 15, 2006 07:23 PM
sudsy
Dec 7, 2005 04:12 PM
Brant
Oct 27, 2005 04:51 PM
viper2x21
Apr 9, 2005 02:37 PM
