engine swap
Old Jun 2, 2005 | 08:33 PM
aaloe1017's Avatar
Default engine swap
Is it possible to put a mid 90's eclipse/talon turbo 2.0 in a 2000 tiburon? I plan on rebuilding it and making my tib a fast *** SOB. If so what type of engine mount mods would i need to do?
Old Jun 3, 2005 | 10:47 PM
05SteelGrey's Avatar
Default RE: engine swap
That sounds like an electrical nightmare. You'd need the whole wiring harness, and most likely a donor car so the tranny, axles, and front suspension would bolt up. Then you'd have to weld custom mounts. Bottom line? Its going to be a biaaaaaaaaaaatch.
05SG
Oh yeah, and it would never pass inspection. Most states require, in an engine swap, and engine that is the same model year as the car or newer. Sorry to burst your bubble.
Old Jun 4, 2005 | 03:43 AM
REDZMAN's Avatar
Anything is possible with enough money my man. We've discussed these swaps several times at www.rdtiburon.com
Why would you want to swap it? Just turbo the hell out of your current Beta mang, they can take the abuse.
Old Aug 4, 2010 | 08:00 AM
2009accent's Avatar
Exclamation Motor swap
Question guys, I have a 2009 accent hatch and was seeing what engine would be best. I here something like a beta or a 2.0, could I use same wire harness. Thanks
skip donohue
Feb 25, 2012 08:31 PM
damonmlime
Mar 29, 2007 06:29 PM
MakingYellowSnow
Jul 20, 2006 05:51 PM
riverking
Mar 3, 2006 03:27 PM
SkiddyK
Jul 2, 2005 05:07 PM
