2003 Tib front rotor removal
Old 06-26-2008, 08:56 PM
jmihal's Avatar
Default 2003 Tib front rotor removal
Can someone tell me how the front rotors can be removed? It looks as if they will just slide off, but they don't. Do I have to remove the spindle nut and remove the rotor and hub as an assembly? Are the rotors "pressed" onto the hub and can come off with a gear puller?? HELP?? Thanks!
Old 06-27-2008, 06:38 AM
Default RE: 2003 Tib front rotor removal
There are 2 set screws that need to be removed but other than that there is nothing holding the rotors on. No, you do not need to remove the large nut holding the axle to the hub.
Hyundai rotors are known to rust into place. As long as the set screws and the calipers/bracket are removed the only thing holding the rotor on is rust. You will have to hammer it off. And trust me, you may have to hammer it HARD to get it off.
I went through that about a year ago.
https://www.hyundaiforum.com/m_8728/tm.htm
https://www.hyundaiforum.com/m_9287/tm.htm
Old 06-27-2008, 08:30 AM
jmihal's Avatar
WOW!! Thanx for tip! Will have break out the BFH!...and lots of penetrating oil!
Old 06-28-2008, 07:49 AM
jmihal's Avatar
StILL working on these....do the phillips set screws have to be removed?
Old 06-28-2008, 09:11 AM
ORIGINAL: jmihal
My original post:
ORIGINAL: NovaResource
Cobras
06-13-2012 03:50 PM
kennyjohn
04-03-2011 04:52 PM
akkernight
07-25-2010 06:13 PM
Stryker
05-12-2010 11:17 AM
Papuda
03-24-2010 12:09 PM
Quick Reply: 2003 Tib front rotor removal
