2006 Gear knob removal
Old 05-21-2017, 01:32 PM
windkind's Avatar
Default 2006 Gear **** removal
Hi all. I bought my first Hyundai today. 2006 Tucson with some minor repairs to be done like replacing the gear ****. Only thing is, I can't get the thing off.
I can't find any info on this model specifically so I'm relying on someone here to guide me please. To me it looks like I should just be able to turn it counter clockwise but it will not budge.
Cheers
Old 05-21-2017, 10:29 PM
avisitor's Avatar
You will have to be a little more detailed about this gear ****??
Is this a nut on the steering column?
Or a nut on the wheel axle?
What does the gear **** do?
And where is it located?
What year and model is it?
Old 05-22-2017, 01:10 AM
windkind's Avatar
I am talking about the gear shifter on a 2006 tucson.
Old 05-22-2017, 10:32 AM
Cheers
I used to own a 2006 Tucson.
You didn't say if this was an automatic or manual but I'm going to assume automatic since a manual trans in the Tucson is a rarity.
It's very easy. At the base of the handle there is a small, oval cover with a tiny notch in the edge. Use a tiny flathead screwdriver to remove the cover. Under the cover is 2 Phillips screws. Remove the screws and the handle pulls up off the shaft.
This should help:
http://www.sound-repair.com/index.ph...-instructions/
Old 05-22-2017, 10:37 AM
windkind's Avatar
This should help:
Hyundai Tucson 05-07 Stereo Removal Instructions / Sound Repair
​​​​​​Thanks, but I have a manual. I can't see any fasteners or clips so I assume it should just twist off.
Old 05-24-2017, 08:24 AM
Yes, it just unscrews
RockinR
03-26-2015 07:06 PM
jh89296
02-16-2012 09:38 PM
Lou
07-14-2011 12:56 PM
breyeansee
05-29-2008 05:32 PM
scubasteve
11-12-2007 05:56 AM
Quick Reply: 2006 Gear knob removal
