2012 Tuscon left rear door lock actuator replacement how-to(?)
Works manually only. Remote and driver's / front passenger's door switches work for the remaining three. Child lock functional. OEM replacement in hand. Panel off, plastic (gently) removed. Where to go from here for replacement procedure...
No factory shop manual, Haynes is unobtanium for this year & model (Mk 2 / Gen2), looking either for the written / .pdf step-by-step from the factory or someone who's done it or has a YT link. Any help appreciated in advance.
Thanks guys.
Hoonery12
2012 Tuscon
215K & counting...
Thanks guys.
Hoonery12
2012 Tuscon
215K & counting...
Before getting any further involved , for good reason, were you able to verify power and ground are available at the door ?
You managed to get this far without any problem, now it is easy to do a few tests . Would be a shame if you replaced a good part and had the same problem.
Sujan Pirani
10-23-2015 05:06 AM
