Tucson Cargo Screen
Old Oct 15, 2010 | 10:00 AM
Ian712's Avatar
Default Tucson Cargo Screen
Hi all,
New here and just had an easy and probably dumb question. Just got a 2011 Tucson Limited and wanted to know if the cargo screen can easily be removed for when I need to put the seats down? Best I can tell you need to use a screwdriver. I was just wondering if there is a release somewhere that I'm not seeing?
Thanks
Old Oct 15, 2010 | 10:34 AM
The screen should be able to be removed by hand. With the screen fully retracted into the bar that goes across the cargo area, push the bar to one side or the other. It's is spring-loaded on one end so it will compress slightly and then the other end can be removed from the mount. Once bar is removed, it should store in a compartment under the cargo area floor.
pezfighter99
Mar 12, 2015 02:08 PM
ZombieHunter
Sep 9, 2014 09:21 PM
swordmaster
Nov 3, 2012 11:04 PM
afewloosends
Oct 24, 2012 02:37 PM
05kas05
Mar 4, 2012 01:52 AM
